Greeeting! :)
Mace
1 hour ago, Tractorman said:
@mace, I am proceeding with my APPS  relocate.  I have removed all the necessary items.  There is a pin that is pressed into a part of the aluminum bracket that I need to remove so I can use the hole for my custom bracket (not made yet).  Did you remove this pin, and if so, how did you do it?
- John
The pin comes out. I literally put a pair of vice grips on it and it threaded out with a little force.
On 11/22/2024 at 8:23 PM, Mace said:
I’m not sure how many rotational degrees it is but it worked the same as the old bellcrank setup. I have full throttle 0-100% when I tested it out of the truck.
I set up my OEM throttle assembly complete with the throttle cable operational for a bench test.  It turns out that although the OEM APPS shaft rotates 45°, the actual foot throttle rotation is about 20° due to the different lever length combinations along the way.  So, that would be much more in alignment with the replacement bellcrank, which has a 20° sweep.  I was overthinking it, as usual.  I will now proceed with using the replacement bell crank assembly.
- John
