Help with Quadzilla 3 cylinder/6 cylinder box
- Replies 32
- Views 4.7k
Mopar1973Man 16 posts
Ltk 15 posts
Royal Squire 1 post
We were right, the harness itself was wired incorrectly. IAT and ECT plugs reversed. New harness arrived and problem solved! 3 and 6 both work with correct values displayed.
Yes sir you can. Just key on and click the switch through the different modes and report back the values seen.
Hey Mike, I contacted Quadzilla Monday and they are sending me out a new PCB board and switch. I will keep you updated on how that turns out. They will send me a wiring harness if that doesn't correct
Hey guys, I have installed the new Quadzilla high idle box (3 cyl/6cyl) sold by DieselAutoPower Mike developed years ago. When I hook it up as it says (IAT sensor and Coolant Temp sensor) I get the following codes and the unit does not work.
I have verified both sensors are in fact working as well as the grid heater relays are both operational. When connecting them back to factory configuration and clearing codes, those codes do not reappear and everything functions normally with no further codes being thrown.
Any idea what I could be doing wrong?
Truck is programmed with a Smarty S03, 3 cylinder idle is active and does work properly with outside temperatures.
Thanks in advance!
Logan Kendrick
606-794-3951
