On 1/8/2025 at 5:45 PM, Mopar1973Man said:
Keep me posted please... :thumbup2:
Received the PCB board and new rotator switch. Installed it, still acts the same. When truck is running and I switch from off to 3 cyl I got a big idle surge and then nothing. Any thoughts?
Quadzilla has mailed me out a new harness so I'm still waiting for that right now.
49 minutes ago, Mopar1973Man said:
Good question.
13 hours ago, Royal Squire said:
@LtkDoes the 6 cyl high idle work?
Nope, 6 cyl does not work either.
Go back and check.
6 cyl should show 26°F IAT and 123°F ECT
3 cyl should show 13°F IAT and normal coolant display.
Operation
Turn switch to setting you wish. Start the engine. Then after high idle starts in 2 to 3 minutes you may turn it off again and high idle will continue till 170°F.
NOTE: To slow of switch change could trigger only 3 cyl mode. If so turn the engine off and wait 10 seconds and restart to clear the previous 3 cylinder mode.
17 minutes ago, Mopar1973Man said:
Go back and check.
Operation
Followed the exact startup procedure you described with the new PCB board Quadzilla sent me. Here’s the results after 5 minutes of idling; 6 cyl mode engaged on the switch, still at idle RPM
24 minutes ago, Mopar1973Man said:
Go back and check.
Operation
Here’s the exact same procedure that I described above , except 3 cylinder mode instead of 6 cylinder. 5 minutes of waiting after restart with 3 cyl enabled before start. No idle change, here’s the IAT and ECT temperatures.
33 minutes ago, Mopar1973Man said:
Still something wrong. Wrong values for 3 cyl and 6 cyl is half right with 123°F coolant.
@Quadzilla Power
Is it possible that my IAT sensor is bad? Zero codes on the truck with the Quadzilla harness unhooked though.
