So I bought a 2012 4x4 1500 with 104k on the clock. Auto trans with electric switch on the dash. Course I looked up the oil and it says to use ATF Here in Tx it gets real hot so I don't think its good to run ATF, what do y'all run?
  • Replies 5
  • Views 595
  • Ram recommends the use of a licensed ATF+4® MS-9602 specification fluid for the NV241, NV243, NV244, NV271, and NV273 type transfer case fluid change.    Automatic transmission fluid (ATF) is oft
  • Mopar1973Man
    I've ran both dextron and ATF+4 for transfer case fluids. Beast with 495k miles I've never had any issues including summer heat in Arizona. Only had to reseal the case once.
Automatic transmission fluid (ATF) is often used in transfer cases because it handles hydraulic pressure well and works in a wide range of temperatures.
  On 2/25/2025 at 3:43 PM, 01_Cummins_4x4 said:
You could use some synthetic ATF+4 like Royal Purple or Valvoline.
Note: All ATF+4 in all synthetic oil and brand name doesn't matter. All have the same specs minimum wise. NAPA ATF+4 is just the same and half the cost at times.
