In Cab Fan, Climate control
If you need to replace the resistor block again, drop the blower & check/clean out the duct work for critter debris. The air comes in through the cowel. The cowel drains are located behind the hood hinges... when I first bought my truck, mice got in immediately & I stuffed behind the hinges with stainless pot scrubbers (SS steel wool). Water will drain, perhaps a bit slower... but no critter access since 2001.To screen the intake on my Cirus, I need to pull the cowel & I haven't been able to... so I have had mouse problems repeatedly.
