I was installing a edge comp today and according to the edge website you must disconnect the neg batteries.. I forgot that part so it tripes a few codes no big deal.. But did it do anything else that i need to fix.. I cleared the codes and the code number was p 0743, p 1765, and p 1693.. Would it of caused any harm to the chip? or the truck? Thanks
  • Replies 3
  • Views 1.8k
Those are both transmission codes both are for the TQ Conv... :rolleyes: p0743 Torque Converter Clutch Solenoid/Trans Relay Circuitsp1765 Trans 12 Volt Supply Relay CTRL Circuit
Thats funny.. I wasnt driving no where.. Was just sitting in the drive. Truck started to spudder and spit then the rpms started going up all of a sudden.. As soon as i unpluged the chip truck went back to normal.
call edge and talk to mark..he can sure help you out....he hooked me up with the hot unlock for :whistle:
