donaldso filters
The links show the same filter. I beleive this is the filter you want https://dynamic.donaldson.com/webc/WebStore/search/item_detail.html?item=49449 It is the same exact media that Amsoil uses, and the exact filter as the Amsoil EaO80. I run the ELF7349 as its paint is cheaper than the Amsoil paint. 20um @ 100% 15um @ 98.7% 7um @ 59.97% It holds more than 20gr of dirt, and AFIK is the best full flow filter you can buy! Normal Fleetguard filters are 35um (OEM filter); Stratapore filters are 25um, so yes this filter is better.
