a/c clutch
a/c clutch is cycling when heat is on. I'm not talkin defrost just regular heat.
  • Replies 2
  • Views 1.9k
The only positions the A/C should come on is...
[*]MAX A/C
[*]A/C
[*]BiLevel
[*]Floor/Def
[*]Def
Now as for Vent and Floor those will not trigger the A/C...
But the nice part of running the A/C is that the A/C is cooling the evaporator drying the air as the moisture freezes to the evaporator. But since the in comnig air is so cold the freon pressure fall rapidily and the A/C cycles off. This causes the evaporator to warm back up and thaw draining the moisture outside. This just makes life nicer in the cab...
