Expensive Injectors
What is the differance between 600.00 60 Hp Dynomite Diesel inj. and cheaper ones. Dynomite advertizes flow balanced and matched to opening pressure. In other words is it worth it?
  • Replies 2
  • Views 2.9k
I personally feel that the best injectors out there are the MACH series from Don M. that said the Dynomite injectors are very good as well, I do feel that the extra money is well spent when it comes to injectors, a certain vendor sold me some cheaper ones and told me they were Mach injectors, the engine never quite ran right and I talked to others that had the same issue, now I have a melted piston due to injector failure, and let me tell you it's a lot more expensive to fix than just spending the extra money for a good set of sticks.just my :2cents:
I personally feel that the best injectors out there are the MACH series from Don M. that said the Dynomite injectors are very good as well, I do feel that the extra money is well spent when it comes to injectors, a certain vendor sold me some cheaper ones and told me they were Mach injectors, the engine never quite ran right and I talked to others that had the same issue, now I have a melted piston due to injector failure, and let me tell you it's a lot more expensive to fix than just spending the extra money for a good set of sticks. just my :2cents:
Ditto!
