today, i was going to install my thermocouple at the exhaust manifold, and drilled a hole and found out that theres a wall inside the manifold right under the center where it connects to the turbo. i tapped it but im not sure if i will get an accurate reading. Has any body had this problem? looks like the place i picked to drill the hole has a wall inside the manifold and the hole passed just next to the wall.:doh:
  • Replies 5
  • Views 3.1k
The manifold is split into 2 halves, which are a bank of the 1st three cylinders and the last three. You have to take the width of the manifold where you want to drill (right where the manifold necks down into the turbo) and divide it by 4. Go in that amount from the edge. So if it was 4 inches wide, you would go in an inch from the side. Dead center would obviously hit the divider, as you found out.
I would figure as long as you tapped into the manifold without drilling directly through the wall you should be ok. Just as long as the probe isnt touching the wall.
thanks, i will close the hole with a threded cap, and redrill where you mentioned, i drilled in the center of the neck and the probe will be touching the divider wall inside.
it is touching the wall
Another view...
You want to be on the rear port... 4, 5, and 6... This is suppose to be the hot batch... Not to mention if you use high idle 3 cylinder you can still monitor your temps. 1, 2, and 3 and dead and cold in 3 cylinder high idle...
It certainly is the hot batch. I had mine on the front 3 but recently moved it to the back 3. I'm thinking as much as 100 to 150* hotter.
