I have been thinking about getting a gauge for fuel pressure, unsure where to mount at this point. But if I get this I should be able to see if fuel has gelled since the pressure will be low. How do I know how much fuel pressure do I need? ETC http://cgi.ebay.com/ebaymotors/AUTOMETER-Z-SERIES-FUEL-RAIL-PRESSURE-GAUGE-DODGE-GM-_W0QQcmdZViewItemQQhashZitem43a08f8236QQitemZ290456568374QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
  • Replies 19
  • Views 14k
Ouch... :spend: Ummm... You might hit the vendors here on the site and see if they have any sales or deals... I know some of the mechanical gauges can be had for as a cheap as $35 to $40 bucks if you shop around. Autometer happen to be the most expensive brand for sure. As for the fuel pressure its normally hooked up after the filter (bottom of the stock filter can). I would say typical good fuel pressure is right around 12-15 PSI for even a common rail.
The only thing I was thinking about with getting this one it tells me right at the injectors what my PSI is so I know the issues are right there or not. Also which vendor to go with?
So does that mean your recommending getting the electric one at the rail? Cause personally I think that would be best cause then you can tell if you have issues right before injector. I guess if I want to have a over kill I could have two fuel gauges one that is at the rail and one that is at the OEM filter. I do like what you did with your fuel gauge setup. I'm just a little nervous about getting it back to gether. If you didn't live about 1500 miles from me I would be on a road trip with a case of ..... Pop.
I would start with fuel psi, and do rail psi later. The H&S (seems to be best package for the 6.7) has the ability to show rail pressure.. so save for that. Fuel psi is about 9-11 on a stock motor, and OE specs are -5 to + 15 (from Bosch), anything over 2 is considered fine on a stock CP3. Yes you can see fuel gelling in a fuel psi gauge, don't ask how I know....
This raises more questions. First you said fuel PSI then rail PSI. the differance is I can find gauges for Rail PSI but not for standar fuel PSI. I checked the H&S site and a no go for that? Help , or link ? Fuel pressure over 2 PSI is considered good at idle... Of coarse going down road should be more right?
That is because rail psi is specific to the truck, where any fuel psi setup will work. These days I recommend the ISSPRO EV2's, 0-40 electric.
http://www.hsperformance.com/mini-maxx/ As a tuner/gauge it can monitor lots of things.
That's backwords. Idle should be 9-11, WOT no lower than 2 psi.
I would love that tuner/gauge. One problem. I still need my left arm for paying for diesel.:cookoo: I am thinking of just getting a stock gauge with a add fuel filter. http://www.glacierdieselpower.com/product.aspx?pf_id=MK27509-BLK . I love what Mike did more did his truck. But I do not feel comfy tearing my rig apart... Just in case I don't have the right tools, or run out of time, money ETC.
So you recommend getting a fuel gauge that is before the injector pump that measures the fuel PSI there right?
Yes, you want to measure your supply fuel pressure.
This is how I monitor mine, its between the GDP filter and the CP3.
Want to install mine :)....... Mine will pry leak. I'm a rookie. I guess I can just tap into the new hoses for the bypass fuel filter there for if it leaks I remove.
The push-locks are pretty good fittings, I haven't had any leak. The fuel filter isn't a bypass as all the fuel goes thru them, and it continues onto the injection pump.
With a push lock, do you just push it on and your good to go? I will probably still use a hose clamp.
Correct, its special hose and fittings. I have never used a hose clamp, and never had a leak. You can't pull it off, you have to cut it off.
Yeap I'm using push loc's on my AirDog and they are awesome fitting... No you don't need clamps they are solid fittings. But to make lift easier dip the ends of the rubber hose in boiling water and place the fitting on the floor and place the end of the hose to it and lay your body weight into it. POP!
