I had a low beam lamp out,tired of buying 1 at a time so bought a set of Sylvania 9007 installed now on constant high beam,won't switch to low? Am i missing something here or did i get a bad bulb,wrong bulbs?:banghead:
I can't believe I am that stupid,but I guess I am:banghead::banghead::banghead:.Can rebuild this motor,modify a fuller 6 speed to this motor,but can't buy the right head lamp bulbs(checked old bulbs 9004).
Stodg hit it... I read the post and found this tidbit...
http://www.candlepowerinc.com/pdfs/9004_9007.pdf
I guess I'll try to play stupid at walmart in the morning,won't be hard i guess,hopefully the person will be even dumber than I play. If not:spend:
On my Sport with the dual headlights I use a 9004, low and a 9007, high. You may have picked up the wrong bulb, as it is just a single high beam.
that confirms my suspicions then the aftermarket sports I have use a 9007 low and 9004 high, backwards from the OEM.
