Codes P1689, P0230, P0232, P1693
- Replies 7
- Views 13.9k
flagmanruss 4 posts
Mopar1973Man 3 posts
The Diesel shop got to my truck. They'll be back on my truck today... so I need advise ASAP!!
You'll recall the dealership told me "No Codes", "Zero Fuel Pressure", "You need a lift pump" ($600 to replace OEM, $1200 to retrofit in tank)... charged me $88 for diagnositic.
The diesel shop pulled codes P1689, P0230, P0232, P1693. Apparently there is a test sequence which can test the lift pump.. it ran.
AAARRRGGGHHH!!!
P0230 - Transfer Pump (Lift Pump) Circuit Out of Range
Problem detected in fuel transfer pump circuits.
P0232 - Fuel Shutoff Signal Voltage Too High
Fuel shut-off signal voltage too high from ECM to fuel injection pump.
P1689 - No Communication Between ECM and Injection Pump Module
Data link circuit failure between ECM and fuel injection pump. Low power, engine derated, or engine stops.
Monitor & Set Conditions
Communication between Engine Control Module (ECM) and fuel injection pump module is monitored when
ignition is on. Injection pump module is referred to as Fuel Pump Control Module (FPCM) in test procedures.
DTC may be stored if the time between CAN messages is more than 3 seconds or FPCM does not receive CAN
message.
Possible Causes
o Wiring & Connectors
o Fuel Injection Pump Relay Output Circuit Open
o Ground Circuit Open Or High Resistance
o Datalink (+) Circuit Open
o Datalink (+) Circuit Shorted To Ground
o Datalink (-) Open
o Datalink (-) Shorted To Ground
o ECM
P1693 - DTC Detected in PCM/ECM or DTC Detected in ECM
A Companion DTC was set in both the ECM and PCM.
PCM is monitored for DTCs with ignition on and engine off and with engine running. DTC may set if a companion module DTC is present. The PCM is reporting it has a DTC present.
Possible Causes
o DTC Detected In PCM
o DTC Detected In ECM
Testing
Using DRBIII® scan tool, clear DTCs from ECM. Using scan tool, check for stored DTCs in PCM. Perform
appropriate test procedure for stored DTCs in PCM.
See DIAGNOSTIC TROUBLE CODE
Wouldn't it have been a beech to have spent $1200 and still not have a running truck!!
The mechanic noted the mouse sign... did not see any damage... yet...
His other thought at this point is a bad ground.
Where is the hard to see ground... behind what?
I've had it suggested to swap out the Fuel Pump relay.
http://forum.mopar1973man.com/threads/3848-It-was-Running-Fine-until-it-WASN-T!-WTF
