Front pump seal
I just notice I have a bad leak coming from my inspection place on bell housing. I am thinking front pump torque converter seal. Any ideas ? Transmission shop says they have problems with torque converter cracking at shaft? And help would be great. Thanks
  • Replies 3
  • Views 1.8k
Ummm... From my old school days with 727 Transmission on V8 it might be a seal failure but more likely a front bearing had failed. It might be time to pull it out and have a shop at least look at the front bearing... I know its cheap to replace the seal but it sucks to have it start leaking again quickly after replacing... (Been there done that!)
Found the problem, pulled the tranny out and found the front pump bolts were all loose, tranny was rebuilt by aamco about 30,000 mile ago by previous owner.
