For Sale - 2006 Dodge Ram 2500- Flatbed for long box bed Winch bumper Flat Bed for Long Box 3rd generation Cummins Tootlbox are included with key I have a flatbed for 3rd Generation dodge Cummins. This flatbed comes with a gooseneck hitch already in the bed. The winch bumper is part of the set. Tootlbox have a key to lock and unlock all box a single key. There is rust starting and electrical will have to be sorted out on your own.
Price: $1,000.00
I've got a story for you all... I got a phone call not too long ago to help a local gent here with a 2001 Dodge Ram 1500 V8 that he had just change the clutch but someone had mickey moused the crank sensor. My first thing was I was going to print a copy of the error codes and take with me. I fired up the web site and start to print the error codes and realized at the last second that the printer is set for single side.
So not to waste paper I flip the power switch off and back on to kill the printer job but left a half printed page jammed in the printer (PAPER JAM!). So I open it up and pull the toner out and carefully pulled the page out. Closed it up still got the error for paper jam. So I hauled to the job without notes.... Returned... Now I took the printer apart looking for broken parts. Trust me this Cannon ImageClass MF4150 printer is not exactly user friendly for taking apart. But I noticed a small piece of white plastic on the top on the printer thae was broken from somewhere. OK just look for the white plastic that is missing something. After about 1 hour I couldn't find nothing white broken... So I put it all back together again thinking maybe I disturbed it and maybe it would work. NOPE...
Still a paper jam... Figuring I was SOL (Crap out of Luck) I would get the old Ink jet out and fire it up and use it. Well that was a mess. The printer is so old there isn't any 64 bit drivers first off and second off Lexmark doesn't have a full driver for it any longer (obsolete). Then to top it off the ink dried up... :banghead: Mopar Mom makes the comment "Well we aren't buying a new printer unless there is a hell of sale on them..."
Great... I know that we both use the printer quite a bit. So knowing this I figured MF4150 is broke with a paper jam and I can't hurt it anymore that what it is... So I got more tools out and got busy tearing it down. Screw after screw I just keep removing everything and looking at every part for problems. I had a huge pile of parts on the floor and desk and just a gut printer frame with only the laser roller left. Careful I remove the paper guide on top and notice a spring was off its hook.
Then notice the rod has a shutter flap that covers a eye that is totally mis-aligned. Could it be this easy?
Well back to reassembly... Screw after screw re-assembled the print to the last 2 screws for the face and realized I had use to longer screw inside.
Damn! So I had to tear it down a bit to find 2 longer screws or swap with the short ones. Got it back together and plugged in... No red light screaming Paper Jam!
Right on... But I managed to save myself about $200 bucks on replacing a printer. Now why did it fail I realize now when I was pulling the paper out I was pull the up half of the page backward and the feeler arm was pulled backwards as well. When it bound up it popped the right side of the shaft up and released the spring for the shaft causing it to never return to a empty paper state but a paper jam state constantly. So I know better to try and pull from the top if I can or go very slowly...
