AGR Performance Steering Gear with Variable Ratio
Hey,Got the email about cleaning inactive accounts. Don't cut me off man! I just started to look into this and figured I would post to make sure I was active. My steering box/ gear appears to be leaking and is a bit sloppy. I saw this at a autopart chain's site. AGR Performance Steering gear. "Super Box 2 Variable ratio 13-16:1 with firm valving for better handling and drivability at hwy speeds. Many performance components like AGR’s tribearing, Billet aluminum caps, etc. All in vibratory finished case."Anybody recommend this or something else? Sounds good, I like the variable ratio idea, but this aint no sports car.
  • Replies 7
  • Views 2.7k
As for clearing you out... You got more that 0 post so you don't qualify... LOL But as for the steering box I would of said to rebuild it yourself. The seal kits are rather cheaper and easy to do yourself if you want to go there. No as for the sloppyness that is most likely the sector adjustment on the top of the gear box. There is a stud with a jam nut on it. You want to screw the stud inwards till it bottoms out then back it off slightly. Don't force it.This might help... As for the steering box replacement if you got the money I would be will to give it a try since its a variable box it might be really nice uprade ot the stock one... :thumbsup Who knows??? :confused:
I have heard mixed results about the AGR stuff. There was a kit at one point in time for retro-fitting a 3rd gen box into a 2nd gen truck which from my understanding was fairly simple and only required a few changes for the spine differences. They say the 3rd gen box is much tighter and more responsive than the 2nd gen gear.Mopar1973Man is right about the sector adjustment. I am sure a lot of steering boxes get replaced due to wear causing slop when a sector adjustment would tighten it back up. Just don't tighten it too much.
Mike, I'm pretty sure that "rack and pinion" are only on 2wd's and/or 1500 Rams. Don't quote me on that though. I've got almost the same front end as you, only the geometry is a bit different...........and Danas vs. AAM axles. Remember, I used to have a '99!!! :thumbsup
Maybe only 2WD. It does say 2500 & 3500 on the listing. :confused:
