power steering
It's making a growling/whining noise most of the time and when I step on the brakes the pedal feels like it slaps back at my foot sometimes.No lights on the dash and I have not changed the fluid. I was thinking pump before I read an old post that turned out to be his gear box.
  • 4 weeks later...
ABS light on?Typically when the ABS light comes on its because of on of the speed sensor is screwed up and not reading properly. I had the same problem it was because of a speed sensor failing and as the ABS unit seen the speeds (left front, right front and rear) were not matching then the ABS pump fights back trying to prevent lock up of the slow wheel.
