leveling kit
gonna put on a leveling kit tommorow any shortcuts or any thing I should look out for I guess I have to remove the plastic on the inner fender well to get to the back nut on the tower do you have to drop the sway bar to get the room to put the spring back in? wish me luck.
You dont need to remove the fender liner, get the shcok bolts from the top of the fender under the hood. Lower the sway bar, remove the bottom bolt of the track bar and raise the frame off of the body with jack stands and lower the front diff to the ground after you remove the wheels/tires. What kit did you get, springs or spacer? How big?
I have a hoist so I have it a bit easier but I just got it off the ground so the axle droops and as stated above the upper tower bolts are easy to get at from under the hood no need to remove any fenders ect just need to remove the shocks. I just used a coil spring compressor and did not unhook a single thing. Worked like a charm.
