- Replies 4
- Views 2.2k
ISX 2 posts
Mopar1973Man 1 post
ricet07 1 post
I am new to the site so I hope this is posted in the right section. I recently installed my valair clutch and after putting everything back together I noticed the 4WD light is on when truck is in 2WD and opposite when in 4WD light is off? 2H (light on) 4H (light off) N (light on) 4L (light off) complete opposite. I didnt disconnect the sensor at the CAD or vac lines anywhere besides at the connector on top of the t case and that went back on the way it came off. Also when the truck is in 2H I should be able to spin the front shaft by hand and I cannot unless the front tires are off the ground which means the CAD is locked and explains the light being on. Now when I shift to 4WD, I HAVE 4WD but the light goes off and the CAD is disengaged so is this possible?? Will the 4WD work if CAD is not engaged but t case is?? Thanks in advance guys.
