LuK Gold clutch .....
Luk is the stock clutch in the truck from the factory... So if you got any kind of power mods I would expect it to hold much more. Typically stock clutch is good to about 300-350 HP to the ground then they slip.Most have upgraded to Valair or Southben Con OFE...Like my stock LuK clutch I broke the hub out of it... :duh:
