Hydrogen power cells
Are you talking like HHO cells where you create hydrogen gas from water?I can't say that I have been you got to keep one thing in mind you don't get something for nothing. With that being said if it is the HHO cells your talking about you'll most likely find out that you put more load on the alternator trying to produce a very small amount of hydrogen gas.
Are you talking like HHO cells where you create hydrogen gas from water? I can't say that I have been you got to keep one thing in mind you don't get something for nothing. With that being said if it is the HHO cells your talking about you'll most likely find out that you put more load on the alternator trying to produce a very small amount of hydrogen gas.
This may be true, but the HHO (Brown's gas) does increase the fuel mileage on diesels and older gas vehicles. The reson it doesn't work good on 'newer' gas burners is because of the O2 sensor. It will see a slight lean condition and the computer will richen the mixture to compensate. It is a lot like running propane, a little goes a long ways. If you want a lot of reading look here: http://www.dieseltruckresource.com/dev/add-hydrogen-better-mpg-t81058.html?&highlight=hydrogen
