- Replies 4
- Views 2.1k
Mopar1973Man 2 posts
flagmanruss 1 post
dripley 1 post
Arrgh...On my last outing I notice water dripping down on the rear corner of the RV. It was leak from up inside near the city water connector. Looking at the plumbing there is a piece of vinyl tubing clamped to the city water fitting and the PEX elbow. So loosen up the clamps to find both are damaged so I might as well replace the tubing too. Gave a firm tug on the city water side and POP! It came off but it broke the PEX elbow. I called the local lumber yard and they have no way of cutting the PEX clamp band. Great!
So I hunted around the property to find the Dremel tool I found a small grinding wheel started slowly grinding the band. Well eventually the band got hot and the plastic melted behind it. POP! The elbow came out with minimal loss of tubing! Right On!
So now today I'll take a trip to the local lumber yard and get Sharkbite connector, barb, 2 hose clamps, and a piece of new tubing!
