Oil Leak - what part is it
So have a small leak on the passengers side of the block up front near the oil filter and front of the block.
That big funny shaped (almost rectangular thing) thats closer to the front of the block than the oil filter or the heater block. Passenger side.
How hard to take off and replace gasket - etc ......
- - - Updated - - -
Very front of the passanger side of the block (kinda rectangular running up and down)
http://roadmasterengineworld.com/images/dodge%20cummins%20engine.jpg
Oil filter might bolt onto it ..... haven't checked but close
  • Replies 5
  • Views 2.4k
You must be talking about the oil cooler?
Or is it the turbo drain line down lower?
thats it !! :) Hows it work.
IS #4 or #6 a gasket ?
It leaks at bottom. Have tightened down the bolts and will see .....
how hard to pull and fix ?
Drain all your coolant and just remove the cooler from the side of the block.That why I don't really think it the oil cooler right off because the coolant should of been leaking first before the oil. But I could be wrong... :sofa:
Drain all your coolant and just remove the cooler from the side of the block. That why I don't really think it the oil cooler right off because the coolant should of been leaking first before the oil. But I could be wrong... :sofa:
hmm ok I get what your saying. I'll clean down the side of the block and make sure its not from something else ..... sure does look like it thoguh .... wonder if the oil passes over the outside of the cooler ... so inside seal is intact .... but outside seal for oil passage is a little weak.
