- Replies 6
- Views 1.8k
Rogan 2 posts
Deafautotech 2 posts
mrtowman4u 1 post
diesel4life 1 post
it is about RWD truck not 4WD truck as it is 1 11/16 that i has it and used it a lot in chrysler dealership in past time but i am still keep it for myself...I am not sure which is correct size socket for front hub/wheel bearing nut?? i has mostly size sockets but i has 41mm that is little more loose to fit in the front hub bearing nut... 41mm is 1.61 inches but i am anal as want correct socket as it is high torque so i dont want put stress on wrong size socket or round on nut...
