High Idle & MPG Fooler
Just a thought....why couldn't I use a manual idle cable. Like a choke cable just to get high idle,as you can see I have too much time on my hands here.I also saw a plug and play 3 speed idle box,don't know if it will work on the cummins yet. Gonna call and ask this week if I remember.
Because of safety factors.
With the high idle flash and box you still have all the safety system in place. The high idle will cancel with...
[*]Touching the throttle
[*]Touching the brake pedal
[*]Placing the trans in gear (auto)
[*]Speed above 0 MPH
[*]Coolant above 170*F
With a choke cable to hand throttle you can't use the exhaust brake as a warm up aid because the throttle is above 0% so exhaust brake is canceled. (virtual loading)
Then also there is no 3 cylinder mode with choke or hand throttle which creates more heat than 6 cylinder. (virtual loading)
