TPS question
619hauler
So my TPS reads 101% on my Quadzilla Adrenaline tuner, and 100% on my Edge w/Attitude all the time. If I unplug the Data-Link connection it reads 0%. My truck always runs as drives as it should. And it does this with 2 different apps sensors. My APPS is under the drivers-side battery.Anyone have any idea what's causing this??
It's an early-04 2500 QCSB 4wd, 5-speed manual. There's no direct connection for the TPS, but from what I can tell it gets read from the data-link connection. And TPS=throttle position sensor....you are correct sir.I can't edit my signature from my iPhone app, do I gotta wait til I get my computer back up and running....
The only that I can remember from my Edge days was the "%Load" that I could display on the "Attitude" screen. From what I remember; that was the % of "fueling" that the "box" was doing at the time.It sure does sound like you've got a faulty connection somewhere.I dunno how to fix it either, because you said it was the same with 2 different units!!!! I dunno man!!:duh::banghead::think:
