DIY, DPF delete, sims
- Replies 12
- Views 13.6k
SnoFarmer 2 posts
CrowsSynthetics 2 posts
KT Performance 2 posts
Rogan 1 post
This topic is now closed to further replies.
Has anyone built a home brew dpf delete?I'm going to do this in the spring.That thing, yes I called it a thing, it has to go.I can't have the over head tell me that the dpf is 85% full, "regen required" and go into a limp mode when I'm 16miles away or more from a road that will let me go over 50mph, with a 24ft t.t. in tow & the family on board.so,What resistors work the best?I've heard of the 330ohms or using 470ohms resistors.Have any of you done this yet or did you order a kit from someone? Next idea, finding a totaled 6.7 in the junk yard (I can dream) and cutting off the truck side plugs to attach the resistors to.
