CS insight readings.
Jim 5150
After install of the insight I set the guages to read boost and frp. the highest the boost got when getting on it was 27.8 and 1.9 crusing. the fuel rail pressure at idle reads 5.5kpsi and and will hit around 20 kpsi when on it and crusing sits about 7 to 9 kpsi. Do these numbers sound right??
Hey Jim at idle rail pressure runs about 6.8 and boost is at 2[ATTACH]4876[/ATTACH]And at wot running around 90mph rail pressure runs about 24.7 and boost is 38.[ATTACH]4877[/ATTACH]I'm running my programmer in the mild setting. Sent from my DROID RAZR using Tapatalk 2
