Starting Problems.
pin8246
Any updates? With 288K miles on your injectors they WILL fail a bench test, even if it's not the issue. Injectors with 100K miles in perfect working order generally wont pass a bench test, it's just what happens.
And this is the case usually............especially with an '03-04. My Bud puts a "not normal" amount of miles on his truck and found this out earlier than most. He's got 340,000+ on his '03 now. I believe the injectors are improved/different in the '04.5+ models. I've got 181,000+ on the OEM injectors now on my '04.5.
