Upon checking my drivers side ground wire I see it has 3 leads. 1 attaches to fender, heavy battery lead to bolt on engine block. Other lead has also been attached to this bolt but I believe it was originally attached somewhere else (maybe frame)? Will it make any difference where this 3rd lead is attached?
  • Replies 4
  • Views 1.5k
Where do I attach the eyelet to ? Injection pump?
I'm not sure what you mean about the eyelet? :think::shrug: The ground cable is the battery lead there is no eyelet I know off. I'll grab my camera in the morning and show you.
My drivers side negative cable has 3 leads, the smallest guage wire is attached to fender/radiator core support. Then there is the medium gauge wire and they heavy gauge battery lead, where are these two suppose to attach to?
