2001 no start/asd relay issues
to start this off ill give yall a little back ground info on the truck
its a
2001 5 speed with 124,000 miles
has the usual mods
dual disk
airdog
150
new injection pump as of 25,000 ago
afe intake
5 inch
exhaust
the truck has had a no start issue in the past but sort of comes
and goes intermittently. The symptoms include, when you turn the key on the is a
3 second or more delay until the liftpump comes on, the wait to start light only
comes on for about 2 seconds and the truck will not start
Also with the key in the run position you cannout hear or feel the asd relay click, ive checked the relay and confrimed that it is working..the truck will roll over for
days but wont get going
today it started doing again after i attempted to
install an edge comp box I got in on trade for some other parts. I will admit
that i had to wire in the 2001 map
sensor adapters and may have gotten them wired wrong, but when i take the edge
harness off and go back to just the boost fooler it still wont start.
my question is could I have fried my pcm/ecm by wiring the map
sensor up incorrectly?
has anyone else had these no start
issues?
thanks for any help
Scott*
  • Replies 8
  • Views 9.4k
Sounds like an ECM issue, even before you had the Edge. Have you pulled the codes?Welcome to the forum, BTW.
thanks for the welcome and ya ive run the scanner and picked up nothing
another wierd issue is that i cannot read the codes through the odometer any more.
- - - Updated - - -
new issue is i no longer have any dash lights.. is this leaning towards a pcm or an ecm
- - - Updated - - -
alright yall ive narrowed down to the ecm, the cel
light, wts light, abs light, and fuel light were flasing on and off at will, the
lift pump would run every few seconds and my scanner would not pull codes while
this was going on...
could i just have the ecm reflashed or do I need to
replace it
little update... the truck is now running... I took the ecm down to cummins southern plains to be tested, it checked out fine so we took it back to the house, installed it and the truck now all of a sudden fired up.. did some more poking around and have come to find out that there is a short somewhere in the harness inside the cab that caused my issue.... the dash lights will come on and off randomly when i wiggle the harness under the dash next to the firewall plug going to take a day off tomorrow and dive into the wiring to find the short thanks for the help yall
Good deal about the ECM! Cummins is usually cheaper than the dealer -- I've been there before, but didn't have all the serial numbers on the engine, so they kinda had to chase down my part. :duh:I know one thing - 9 times outta 10, finding a short is not fun. Good luck, sir!
I would double check all wiring that any modification might of tapped into. Sounds like there is a network bus issues too. I know its not displaying the NO BUS message but the fact there is a lack of ability to dump error codes. You might double check all dash grounds as well as engine grounds.
where are all of the dash ground located?
  • 10 months later...
Update to this!!
All fixed
Alright after driving the truck for a couple months while still having the no start issue on and off I finally figured it out... the fuse block inside the truck is a two piece design that tends to come apart causing a bad connection to the fuses... my dash lights and no start issue were resolved after fussing with the connections until they were right.... hope this helps
