Tires: Treadwright
Rogan
Just my .02 cents here guys...............I run my Cooper Discoverer AT3's at 70psi front and back on my 3/4 ton '04.5. I'm too lazy to "air up" and then "air down" as I hitch and unhitch my work trailer daily. Prior to these tires I ran the OEM Michelins and the Cooper ATR's at 70psi front and back also. Got 81,000 miles on the Michelins and 74,000+ on the ATR's before the current Coopers. Almost 34,000 on the AT3's now..............and they have probably 65% of tread left.Since I've been driving, I've always run my tires "hard". Better mileage and less heat build up that way. IMNTBHO; if your tire is "properly" sized for your rim, you should be able to run "max" pressure without abnormal tire wear. I've done it for years!!!:smart: And "knock on wood", I've always had great tire life!!!:2cents:
