I just put on two new stabilizer links on the front. No problem installing them except for knowing how much to tighten the nut down on the bushings. They tightened easily until I ran out of threads. Is there a proper squish value on the bushings? I also tighten sector shaft adjustment on the steering box about 1/8 turn and it seems to be working better on the test drive here at home. I am leaving for Indiana shortly and will put it to the test then.
  • Replies 25
  • Views 3.9k
Dave, the adjustment is on the top of the gear box. Make sure you shut the truck off to adjust it (for safety's sake). I don't know about the DSS for a two wheel drive, but I know they make one. Another problem to consider is these trucks have a large span of numbers to be "with in spec" for alignment. I have had mine aligned four times in one year just trying to get somebody who knows how to align these trucks. The last place I went got it close, but I wound up straightening the steering wheel and also put a touch more caster in the left side so it would quit pulling to the right. It does drive better, but not as good as it could. I have not been able to get the numbers that the two wheel drives need to drive good. I do know that most shops don't put enough caster in to hold the road good.
I generally tighten them down to where they just start to squish a little.as for sector shaft, I had to adjust mine last weekend. 7/8 turn it took, to get the 10:00-2:00 slop out. There's no binding, and the steering is much better. Although I know I need a new steer gearbox, it'll have to wait.. :spend:
Oh boy, not good news, I'm thinking the same. Where is this sector shaft located?
Dave
Dave
Read my post right above yours.
Oops, dang phones, thanks.
Starying in a dorm room for the last two weeks can't get my laptop to connect to the new wifi,
Thanks MnTom!
Dave
