I have found one a guy wants to sale, it's 4x4 with 218xxx on the motor,it has the 5speed trans in it body is clean decent intereior what would be a fair price for the truck as far as I know it's all stock.The temptation is calling been wanting a 02 for awhile so I can mod. it up a little bit and the fact that I miss my standard trans.THANKS
Ball joints? Brakes?Control arms? Hows the clutch?When was a new injector pump put in? Extra cab?That truck would range from 8-12 here depending on the above, color, and condition.
I just bought an 02 with 246,xxx. It was the laramine addition, ext cab, short box, with a 5 spd swap. I picked it up for 7500. I have attach my personal maintanance records and this is what i have had to put into it so far. Also check engine light just came on yesterday, front axle passenger side seal leaks, oil leak from somewhere in the front of the engine and transmission leaks.post-12849-138698205341_thumb.jpgYou may want to look at these things before you buy and get an idea of what your going to have to put into it.
