2001.5 Emergency Brake Article
looking at the pictures I thought that you had rear disc brake pics and earlier drum brakes mixed in the article. Now I realize that there is a set of drum shoes inside there for parking brake. Wow, :banghead:Do these shoes wear out very often? Should I plan on replacing with my rear pads/rotors?
They will wear out. When you do the rear brakes you can pull the rotor and have a look at them. I just replaced mine but had a leaky seal and the one side was trash. IIRC they dont have alot of pad on them when new.
