helpppppppp
my obd11 port fell apart and the radio went out put it back together and tried to connect my smarty nothing, Checked the coded on the cluster im throwing a 1694 no bus message idk what to do is there a fuse to check because the radio also went out please help!!
the obd11 port got kicked and the plastic piece that slides over the pins was loose and fell off well in the effort to slide it back on the radio went out. So i put it all back together just as it should and no power, so i forgot that the #12 fuse powers that and sure enough it was blown problem solved so now the quest is for a new plug lol
