OD button intermittent
"Anybody had any trouble with their OD button on the gear shift working intermittently? The problem seems to be a possible dirty switch but I don't want to guess. Ideas? Works both ways, shifting into OD off or on, can't get the thing to go even after several attempts.
If you drop the lower knee bolster cover and/or lower column cover, does your button have the small 2-wire connector for the OD button?
If so, you can get a small momentary switch from radio shack for a dollar or two, unplug the connector, poke the momentary switch wires into the truck-side connector, and test it with the small button.
If it works fine with that temp switch, then the button in the stalk is flaky, most-likely. It pops out of the stalk.
