Suspension help
I have a 3in lift on my truck and I'm thinking about taking it off does the suspension sit level with blocks and coil spring spacers takin off?
  • Replies 25
  • Views 5.5k
I can't see sigs on my phone but I am going to say no. If you want it to sit level you would have to raise the front back up. Usually 2" does the trick. Why you wanting to take off the lift. Sent from my iPhone using Tapatalk - now Free
A
It's got 3in blocks in the back and spacers up front I'm gonna take it off when my 35s off truck isn't geared for 35s
Gotcha. Let me know if you take it off, I may be interested in your spacers. I need to get mine leveled out myself. Sent from my iPhone using Tapatalk - now Free
These spacers won't level it they aren't 2 in spacers but if I gotta buy 2in spacer to level it I'm not gonna take them off
Each rig is a little different, I could use 3" to actually level mine, but it would sag a little when hooked to a trailer I suppose. Most use the 2" just for the best look loaded and unloaded. Sent from my iPhone using Tapatalk - now Free
Each rig is a little different, I could use 3" to actually level mine, but it would say a little when hooked to a trailer I suppose. Most use the 2" just for the best look loaded and unloaded. Sent from my iPhone using Tapatalk - now Free
These spacers up front look to be around 3in as do the blocks in the back that's why I was wondering if it would sit level without them I was gonna take the lift off to see how 33s drove with the 3.55 gearing and keep the lift for later on.
I understand. I run 35's with no spacers (4:10 gears) , 33's will look good and be lighter on the wallet too. Sent from my iPhone using Tapatalk - now Free
Do these truck come from factory with blocks in the rear?
Yes they do. Most likely, what you're seeing is stock rear suspension with a "leveling" kit on the front coils.
Who in there right mind would set a truck on 35s with 3.55 gears what would I need to do to make it sit on 33s level?
with stock blocks and no coil spacers, it'll obviously be high in the rear (since it's designed to carry weight and sit fairly level with weight on it).If it sits level now, with 35s, it'll sit level with 33s on it.Remember, you're only lowering the truck's overall height by (at most) 1" when dropping from 35s to 33s.
with stock blocks and no coil spacers, it'll obviously be high in the rear (since it's designed to carry weight and sit fairly level with weight on it). If it sits level now, with 35s, it'll sit level with 33s on it. Remember, you're only lowering the truck's overall height by (at most) 1" when dropping from 35s to 33s.
So if I take off the spacers in the front and the blocks out of the rear it will sit level? And if I pull those out will it sit high enough to clear 33s?
Are the blocks double-stacked in the rear? There should be a single, roughly 3-4" tall block under the rear leaf springs. If that's what you have, then that is a factory rear setup; leave the block in.
It is roughly 3in block but the gearing isn't enough for the tires and it would look stupid with 33s sittin as high as it sits
Careful now. I have stock 265 75r 16's on mine and it looks fine. Mine is just not leveled like yours. I would not like the squatted look when I put a load on it.
I didnt mean it like that I just don't see why the blocks are needed on the stock suspension other truck look like they sit a lot lower than mine
The blocks are indeed stock and really the only reason another truck would look lower than yours might be its a 2wd or its sitting on smaller tires. I personally think it would look just fine on 33's. As previously stated, 35's are not generally an actual 35" and the difference in 35's and 33's will be about 1"
I just figured that they had smaller blocks from factory that's why I was wondering I haven't measured the blocks they just look around a 3in
I should have put some smileys in that. I did not take it that way at all. Its all about how you want your truck to look. If you want your truck level while empty, go for it. A lot of folks like them that way. I personally like the forward rake while empty and a level stance while loaded. Mine came new with the same blocks in the rear you apparently have. If you put 33's on there it will still set level. Remove the front spacers and it will have the forward rake to it.
I'm glad you didn't take it that way the way it came out wrong and I just got the truck about 4 months ago cause I've always wanted a diesel (if I had the choice I would go back because of fuel and maintance costs) its more of a daily driver I don't haul anything but a couple 4 wheelers from time to time.
