Multiple codes
Well, went to go to work and this morning and NO GAUGES!:cry: That was short lived, guess the PCM is shot, why would it work yesterday, after the flash, and then overnight just go dead? Ordered a PCM from Auto Computer Exchange today, it should be here tuesday, hopefully that brings this to a close. It was weird cause the gauges came back on today for about a mile then when I started the truck again....DEAD gauges. Oh well, at least I will know what I have till I'm done with this thing!
UPDATE I put the new PCM in last night from Auto Computer Exchange, still having gauge problems!:banghead: They come on and off and sometimes just the speedo and tach go out then the air bag light comes on. I was told these new PCM's are programmed/plug in play. I don't know what to go after now,let me know what you guys think, I am about at the end of my rope.
Are you sure it was a new one, I am thinking reman. I would call ACE, you might have a bad one. I went this route with my ECM, after 2 tries and about 8 weeks I got one that worked except for cruise. It crapped out about a year later and now it is a paper weight. I dont know that is the issue, but I would be suspect.
I dont know if it is reman or not, but it is supposed to be programmed by your vin # and not have to be flashed by the dealer. I suspect another $80 trip to the dealer will be in my near future. I will call them and find out if I need to send it back to them before I go to the dealer.
I would definitely talk to them, mine was not a flash problem it just did not work. My oe went out with no 606 code. but the first one I received did not work and spit out a 606 code, freshly rebuilt and flashed. The case however looked like someone had pried it apart with a screw driver.
They said I can take it to the dealer and flash it, no warranty issue. I am going to check my alternator again just to be certain before I have it flashed. I noticed some T/C issues this morning so I gotta try the alternator test.
I have not made it to the dealer yet, the stupid gauges worked again yesterday, then this morning....no gauges! I don't know what to think anymore,if the PCM was progammed wrong the gauges should not work at all, right? I even replaced all my battery ground cables yesterday,and I did find that the alternator wires( 2 wire plug) had nicks in them so I taped them up as well. I could not get a good readings for the alternator test on my meter, hopefully the meter I have at work will do the trick on that. I will keep looking for this Gremlin, or does anybody wanna buy a 99 dually with no gauge cluster? Just Kidding....I will find the problem....I will find the problem....LOL
