transmission overdrive & lockup solenoid?
- Replies 2
- Views 1.9k
MnTom 1 post
CTcummins24V 1 post
47re troubles: Replaced governor solenoid and sensor and filter last year, did band adjustment, tranny still slams into 4th unless I plan the shift and let off the throttle. Tranny searches between 3rd and 3rd lock-up with OD off going slow on the back roads but shifts strong at throttle. Transmission overdrive & lockup solenoid? Speed sensor too? Something else to replace while I have the pan off?...can't afford a built tranny till at least next year
