- Replies 31
- Views 6.5k
chrisrmerritt 15 posts
Mopar1973Man 4 posts
diesel4life 4 posts
Ilikeoldfords 3 posts
Hey guys, Now I know iv'e been over this particular topic before but iv'e come to view some new info regarding lift pumps well new to me anyway lol. So I was vewing some threads on here and came across the Assassin lift pump, and read that these pumps actually increase pressure with RPM's which of course I really liked that, and the fact that there a mechanical pump. Also during my discovery i read that in order to install this pump you have to replace the draw straw. Is this something that absolutly has to be done with this style of pump? My original choice was a Raptor 100 but also viewing some threads on here I discovered that the new owners of AirDog F..... them up so am not sure I want to go that route. And then I found the below from Homestead, and really liked this idea because of the costs. My truck is bone stock, and I dont really plan on towing anything maybe a car, or when I decide to relocate and load all my crap on a trailer and go other than that 95% of the time my truck is empty. Dont really plan on doing any mods to it other than a 4" or 5" exaust although +50hp injectors are appealing to me more, and more lol. Allready got my BHAF installed!!
Just trying to figure which one would be best for the cheapest price before my stock LP craps out on me. Bare with me gents! Below is Homesteads post! My "kit" is parts and pieces from Vulcan as well as stuff sourced from a local parts store. The tank module is factory stock, no draw straw at all. The connection to the tank is factory as well. My "big line" actually starts just before the tank itself on the frame rail.The Carter pump is mounted directly below the drivers seat on the outside of the frame rail and feeds the factory filter canister/heater assembly. From there is is "big line" directly into the VP. The pump wiring was extended down to the frame mounted pump using a Vulcan harness but they are simple enough to make.Everything is Push Loc type rubber hose, braided or anything is not needed. Push Loc is cheap and available just about anywhere and way less hassle that braided. I had braided at first, waste of money for this application.I have my stock OEM Carter set up this way, been that way for over 150,000 miles on the same pump. Pressures are 15/16 psi at idle and WOT won't go under 11 psi. Big line from the front of the tank to the VP with only the factory filter canister in the middle.Jeff
