Just got my edge juice w/ attitude CTS installed and was wondering what the safe temp ranges for Trans. and egt's are? Truck is a 2001 3500 24v w/ auto. I could not use the supplied boost elbow either. Will that affect much? Should I be concerned with any other temps?
  • Replies 5
  • Views 1.9k
I had my backdown set at 1200-1250 on egt and trans temp shouldn't see much over 190-200. Get yourself a turnbuckle since you cant use the boost elbow on your hy35 turbo.
How's your fuel pressure?
I have not got the fuel pressure hooked up yet. I am waiting on my push-lok tee since I couldn't use the supplied banjo bolt. With that turnbuckle what kind of boost pressure should it be set to? I assume you have to set it.
Don't push your HY35 past 29-30 PSI.I wouldn't run the Edge until you know what your fuel pressure is. What kind of lift pump do you have?
I have the fass 95. It was installed about a month ago. I was told by the shop that it is running around 15-17 I believe.
