- Replies 4
- Views 2k
MnTom 1 post
ISX 1 post
Wild and Free 1 post
Clunk 1 post
Engineering, The perfect partnership between physics and design, a tangible record of man greatest achievements, created out of necessity perfected with technology, built to endure the test of time. The world is altered by these creations, some assist our way of life some promote our demise, engineering is a complex mysterious and ingenious idea brought to life by invention, machines used to build machines, some have limited purpose superceded by a new idea, but every so often that idea become a mechanical masterpiece, one that can not be surpassed and can not be made redundant by a new design, the two stroke engine is one such masterpiece it's power to weight ratio is Superior, 30 % higher then the equivalent capacity 4 stroke, it naturally aspirated, needing no assistance from a accelerator pump or fuel injection, it receives a full power cycle with just two strokes of its piston, induction, compression, combustion and exhaust, there are no valves controlling each phase, instead the piston reveals intake and exhaust ports in the lower half of the cylinder, The piston travels up the cylinder like a syringe drawing air and fuel into the crank case through a one way reed valve. It's an organic exchange of vacuum and pressure as the piston pumps fuel and air into the cylinder. At 10,000 RPM the spark plug ignites 166 contained explosions of power every second.
