hey yall need some help here. Had to replace my injectors due to multiple bad injectors (shop did return flow test). Ordered injectors from diesel care and when I installed them the truck idled fine for about 5 minutes then i pulled out of drive and gave it a little bit of gas and heard a ting sound and truck started dumping white smoke with rough idle. Got back in garage, figured injector wasnt seated properly and pulled all injectors and tubes. One of them had a clean tip so i figured that was the injector that unseated. reinstalled everything, started it up and once again dumping white smoke with rough idle and a knock. Called diesel care and they suggested caping off each fuel line at the rail and see which one stops the smoking. they think that the system wasnt primed properly and air made injector stick open.
Could this be the case? should i cap rail and see or should i pull all injectors and send all back (already not happy cus injectors i ordered were backordered and they sent me 40 overs instead of the 50's like I wanted)?
Thanks for any help!
03 Cummins common rail
Video of truck idling: http://www.youtube.com/watch?v=AfDbbNmhbHs&feature=youtu.be
Edited by wakerc
