Just like the title says... the truck won't shift out of 1st at any throttle position unless I take my foot completely off the throttle, then get back on it. Once it's out of 1st and past ~28mph, it shifts 2-3 and 3-4 completely normally. It will try to kick down into 1 if I go WOT/WFO under about 45mph. And if I floor it at low speed, it'll hold 1st all the way to redline, and won't shift.
Is this a governor issue? I replaced the solenoid and sensor back in 2010 with dealer parts. I'm ready to order the Suncoast governor kit, I just want to make sure it's (probably) not something else...
  • Replies 8
  • Views 1.3k
Could be a kick down cable, band issue, or gov problem. I would get a gov pressure sensor and borg warner gov solenoid. Do a trans service with band adjustment and add a bottle of lucas trans fix. I dont know if the hd kit is needed but that isnt a bad price. You can get the sensor and solenoid for about 120
You wouldn't have the FSM adjustment procedure handy, would you? :cool:
