ecm question
Just got thru getting my ecm rebuilt. Truck starts and runs good,but still has lots of codes.p1693,ecu codes 0521,0237,1698,0230,0382,03801689,0118.Doesn't have any check engine lite.Do  I have to take my truck to dodge to have my ecm reflashed,or can I just get the codes cleared and get it to pass emissions?
Any suggestions will be appreciated.Thanks
2202, 2500 4x4, clubcab,auto,winch, sidebars 95 gph fass,industrial injection vp44 22ft Terry 5th wheel
Have somebody clear the codes. Most likely just stored codes. You can buy a cheap bluetooth reader off of amazon for 20 bucks that will read codes and clear codes. All you have to do is download an app on your phone
Thanks for the info mopartecnician, any particular one you woul suggest ,there's a whole bunch of them on amazon.
As soon as I have some extra coin I am going to nab up a scan gauge. Seems like it would be extremely handy. Mike, Is there any engine data that it cant read? Or can you basically see every sensor?
As for what I can see
IAT sensor
ECT Sensor
MAP Sensor (but the value is incorrect on mine but newer version seem to be corrected with a boost gauge)
GPH flow of fuel burned
Load of Engine
RPM
MPH
HP (Calculated HP at the flywheel)
Charging volts
There are more...
IAT sensor
ECT Sensor
Load of Engine
RPM
MPH
Charging volts
There are more...
After weighing all the options, I went ahead and bought as scan2 thru amazon.Thanks for all your posts gang.
Like myself I've got a ScanGauge II for code reading and reading live data of the engine.
Just hooked up my new scan2 guage.Tried to clear all those codes .Got the no response message,looks like I'm going to have to get dodge to reflash my ecm,unless somebody has some other ideas.
