- Replies 8
- Views 4.4k
mr.mindless 3 posts
dorkweed 2 posts
AH64ID 2 posts
MnTom 1 post
Hey everybody, it's been a while! And I'm back with a problem...
07.5 6.7, 370k. Two owners ago supposedly replaced the whole top end of the motor at about 320k chasing what turned out to be a bad EGR cooler. The truck had been stock until then. It got a new head, new turbo, new injectors, and an H&S with SmartyJr. I run either econ or tow with default values.
I've had the truck for a year and about 15k miles. It has been flawless with the exception of what sounds like chipped teeth in 5th gear that I'm ignoring... The last few days I've noticed what feels like a miss under high load. I have an Insight CTS, and watching what it's telling me I see no oddities in rail pressure, EGT, load, anything. It happens above about 20k rail pressure. If I back off it smooths out, if I upshift and lug it the rail pressure drops at a lower RPM and it smooths out.
I have no smoke, no gained oil, no rough idle, no miss at low load. It's pretty subtle, along the lines of an exhaust leak. I had no end of issues with injection lines on my P7100 24v though and it's attuned me to what a dead hole feels like, and this doesn't feel right.
I did get a tank of watery fuel over the winter once. I'd be less concerned if it wasn't for that.
Planning to pull all 6 sticks and bring them to D&W Diesel for testing. Crappy thing is I have a race this weekend and would like to tow down Friday morning, and they're backed up a couple days on testing!
