VP44 Poll
Off topic I do live in Wisconsin and often see negative temps through out the winter and am yet to have a problem with my stock lift pump which has been replaced once and to my knowledge the vp44 is original i got the truck at 120,000 and acording to the dodge dealer the lift pump was just replaced and the vp was original I just started the two stroke oil diet about 10-15 thousand ago and my two questions are how long do i have before they dump and aparently this is unusual that they last this long? Im just starting the proccess of instaling my fuel pressure gauge so i'll post again since im curious of my actual pressure and the drop I get when my heaters cycle with the stock lift pump...
120,000k is a long time but it's not the VP that doesn't last it's the lift pump that doesn't, which you already went through one. If you can catch it in time, you replace the lift pump and the VP doesn't know the difference, the VP's go out when you continue driving with low pressure and it gets hot and probably doesn't have much lube so it dies on you. They will last inevitably, as long as they have sufficient cooling and lubrication in the fuel. Getting a good lift pump ensures this along with the 2 stroke thing.
