  • Replies 6
Sounds like a contaminated catalytic converter to me. You are probably going to be replacing it real soon.
Well after the spark plug change and a short test drive the CEL light stayed off so far and she is going to test drive it tomorrow on the mail route. This little Subaru has well over 300k miles (second engine) and does about 134 miles per day delivering mail out here. We'll see I'll keep you posted.
If you have a scanner that can read the mass air flow sensor and the o2 sensors make sure they are moving evenly. I've had this problem on an 05 imprezza 2.5rs and found that it was a bad mass air flow sensor.
  • Current Donation Goals
    • Raised $20
