I agree. Stealth plate is much cleaner and no more broken wires too. Not to mention, it keeps everything sealed up nicely. Even if you do get a good wire tap, you still will always run the issue of corrosion and breaking the wires over time.
Like said before, that wire is not replaceable. Just have to solder it if you want a decent fix.
Edited by Ilikeoldfords
